Thread: ESP and TC
Old Aug 16, 2008 | 04:12 PM
  #43 (permalink)
stevieb's Avatar
stevieb
Default Re: ESP and TC
Originally Posted by BlueStorm
You missed my point, the lager rear wheels cause understeer and over power the front skinny wheels. if you match the wheels they will reduce plowing.
also if you want more traction get a posi unit. turning off the entire ABS/TC/Stability Contol unit is not a smart thing.
what's the obsession with burning rubber anyways? I can turn off the TC and easily slide the car around corners safely with out this silly modification.
Try sliding easily around a corner with just the traction button pressed and you will find the ESP kicks you into touch.
You missed my point, hard launch in a straight line and the crossfire nose dives even with the traction off.
This thread isnt just about just spinning the back wheels its about being able to do things with your car without it stopping you mid stream.
Steve
