Re: Show us your Engine bay
x justin,
looking at yours, i like the idea, but it looks like your filter is sitting in a hot spot. did you remove all of the crap around the hole the original tube went through to open it up bigger? if not, id do that, and i'll also suggest you build a barrier beside the filter to keep the air passing through the radiator from contact. simular to most k&n setups you see.
