Re: ESP and TC
On my srt 6 i just disconnected the esp-and tc wire in the little box in front of the batt. I had to try and see if this would help me at the drag strip,
burn out # 1 about 3 to 5 ft and then went like hell============
held the brake ,it spun for about 10 ft the felt like it bogged not sure so i did that one again, repete spun for about 10 to 15 ft and car went like hell,
repete this with my foot on the brake and with our the brake everything was good.--------------------------------------------
Then i was looking for water to try it ,,no water, but i found grass, wet green grass . --------------------------------------------
spun 1 gear 6000rpm,2 gear 4000 rpm, and held that for a few seconds,,,,, then moved to blacktop, stoped ,wot took off spun about 5 to10 ft and car took off fast. had to repete that knowing the tires were wet, this time on the black top took off holding the brake spun,fishtailed but went like hell, went back to the grass and this time spun through 2 gear into 3 gear all looked good, slowed down then pulled on the street made a right turn and no supercharger,, all these runs were made in 10 to 20 min so i wanted to see if it got hot and shut down,, went about 3 blocks pulled over and shut down the engine, restart, every thing back to normal, made three more dead stop ,,,full throttle , and two more holding the brake and then at 1500 letting the car go so as far as i can see it will work. next i will try it at the track. total time from leaving my house driving to a main road and doing all the burn outs and back to my house total 25 min, jim
