Old Aug 20, 2008 | 07:06 AM
  #84 (permalink)
mrphotoman's Avatar
mrphotoman
Default Re: Experimenting with Toluene
Originally Posted by Infinite
tolulene is destructive to the seals used in the injectors... most aftermarket injectors are seal-less but the stock ones are not
they cause them to get brittle over time and eventually will fail. causing an injector to stick open, or even worse.. break. leaning out whatever cylinder it feeds
He will not listen to you, he wants to use it so let him.
