Old Aug 21, 2008 | 06:23 PM
70GT6's Avatar
70GT6
Default Re: Cabin Filter and Base Coupes
Originally Posted by brucero
I have an 07 base coupe, I'm trying to determine if a cabin air filter is in the car, or if one can be installed.
How did you gain access to where the filter was.
I looked under the passenger footwell area, and there is a plastic perforated piece there with no obvious access.
Should I start unscrewing stuff, or can you give me some hints or directions.
While under there - you can see the fan motor. There are white/yellow clips that hold the motor& fan in the car. About 6 inches toward the center of the car there should be a 2" x 8" (about) rectangle piece of plastic held by clips similar to those on the fan motor. Sliding the clips releases the cover and reveals the filter. Pull down to remove filter (if there)
