Old Aug 22, 2008 | 03:55 PM
70GT6's Avatar
70GT6
Default Re: Cabin Filter and Base Coupes
Originally Posted by brucero
70GT6,
Thanks for the information.
There is nothing under the passenger foot well on my 07 Base Coupe other than a large perforated piece of plastic which covers the entire area.
It seems to be held in place by two screws right behind the glove compartment.
Can't see the fan, or anything for that matter.
There is supposed to be a kneee airbag on the 07's and maybe that plastic shield has something to do with the bag... don't know, but I'm not going to play around removing stuff that could go boom....
I appreciate the reply,
Bruce
Passenger airbags are in the door and on top of the dash.
There are 2 screws that you remove to drop the perforated panel that you are seeing. Then you will be able to see the base of the fan/motor, and filter base (an the clips holding them in place).
As for cleaning the filter I guess you could - except one type of filter is charcoal made to filter oders - when these go bad your interior has a "pickle juice" smell (someone else came up with that but it is fitting)
