Old Sep 8, 2008 | 09:29 AM
  #141 (permalink)
sonoronos's Avatar
sonoronos
Default Re: The official eaton supercharger thread.
Originally Posted by ChuckNorris
I don't think it would work seeing as how they are able to read 22 psi and not peak. The scale is probably too large for it to adapt. The ideal map sensor would hit max voltage at 9psi and still be around 1.7 volts at 22" vac. Anyone have any ideas... Maybe one off my wifes A4 1.8T would work it runs low boost. I'll have to check the voltage.
Just do what the honda people do. Use one-way check valves to prevent boost from reaching the map sensor.
You don't need the MAP sensor to read boost. Just make it read atmospheric and let the FMU deliver the fuel.
