Originally Posted by 70GT6
I could not hear mine either.
When you bleed the system - you will see the coolant.
Bleed - clamp (pinch) the return IC pump hose just above the "T" near the recovery tank. Start the car and blip the throttle this will be enough to start the pump. Watch until air bleeds out and you get a steady flow of coolant -it can be seen flowing in to the tank.
(if needed there are some pics on there somewhere)
do i need to pull the wheel back off to get to the ic pump hose above the T? i tried to find the pic but was unsuccesful.
Thanks for the help.
