Originally Posted by mrphotoman
do i need to pull the wheel back off to get to the ic pump hose above the T? i tried to find the pic but was unsuccesful.
Thanks for the help.
No - the hose is located between the "radiator/fan" area and the recovery tank. You can get to it from under the hood.
You will see a hose come out near the top of the motor and head toward the recovery tank. The hose will go down to the IC pump area. Right when the hose passes by the recovery tank there will be a "t". Pinch off the hose just below the "t". This will direct the flow to the tank and bubble off the air in the system.
