Old Sep 13, 2008 | 07:16 PM
mrphotoman's Avatar
mrphotoman
Default Re: Brown and red wire on intercooler pump goes where?
Originally Posted by 70GT6
No problem with the vac looking hose.
If the pump did not turn on you may have to get the engine a bit warmer.
Carefully open the recovery tank (not when HOT) warm is ok. You will see a flow of coolant from the area where the hose/"T" enters the tank.
If you have nothing after this - you better check the wiring.
so i should see it flow without pinching the hose?
the coolant is dark green so it is hard to see it moving. i will check it in the morning.
thanks
