Old Sep 17, 2008 | 09:29 AM
rcompart's Avatar
rcompart
Default Re: NoKeyGo - Keyless Proximity Entry, Remote Start, KeylessGo Pushbutton Start!!!
Originally Posted by Voyager
and turning off the car i think if its quick 3 CLICKS not seconds. and if its not 2. i could see accidentally turning the car off more annoying but i and this is my opinion would be fine with it being as fast as possible as long as it could only be turned off IF THE CAR IS IN PARK.
K, so here's what I guess we can do, if car is in park and the brake is depressed (manual, parking brake set, clutch and brake depressed), you can start the car by pressing the button three times quickly (click click click) and it will turn on and start, if you do it again while the car is on but the engine isn't running in a manual and the brake and clutch are depressed, no parking brake needed to be set if the car is still on), it will refire the engine, and if you the car is in park, the brake is depressed (Manual, parking brake set and clutch and brake depressed) and you hold the button for 2 seconds, it will turn off.
Sound like a plan?
Key thing is to make this work for both the auto and manual and not be overly difficult to learn or use.
