Originally Posted by Rob M
4 years ago i bought a replacement cannister for around $60. even at that price it is a waste of money. i would not recommend replacing it at all. keep a vulcanized rubber tire kit ($4-10 at any automotive store) and a pair of needlenose pliers in your car to remove nails, etc. and repair punctures. the biggest problem with using the liquid sealant is that it will clog your valve stems and cause your tire pressure monitoring system to malfunction.
thanks for your reply. i guess that i should have taken the tire to the store. as you mentioned the monitor is now malfunctioning. i guess that's the chance you take if you can't do anything but try to get moving again.
think i'll take a look at the suggestions members have posted about possible spares stored in the car (slk?). happy motoring...
dab
