Old Sep 21, 2008 | 05:46 AM
waldig's Avatar
waldig
Talking Re: Supercharger Noise - Take a listen
First of all there are some square ball bearings in there somewhere.
I would get a garden hose to listen to the sounds and localize them as to the physical source. You could also go to harbor freight to get a mechanics stethoscope for even better localization.
Another test proceedure is to remove the fan belt and start the motor for 20-30 seconds to confirm that the noise is due to an accessorie and not motor noise. I would do this just before I started swapping the s/c swap because you would already have the car ready to break down and it is an easy test to confirm the noise.
Finally THE S/C DOES NOT RUN WITH THE A/C. YOU WILL SEE IT ROTATE AT IDLE BUT IT IS NOT ENGAGED UNLESS THE CAR IS IN GEAR AND UNDERLOAD.
The video explaining this is on http://www.youtube.com/watch?v=h9Exe2rxYgc
The write-up is in
Supercharger runs almost all the time, here is the video, TAA DAAAA - 09-17-2008 , 05:26 AM
Enjoy, WOODY
