Old Sep 22, 2008 | 09:53 AM
Montana Crossfire's Avatar
Montana Crossfire
Default 185mm Pulley how tight is to tight?
This is a VERY basic question that I should know the answer to, but since I am running non-stock pullies on my SRT I must ask. I had a LET water pump pulley failure recently on my 185mm setup. Other than the amount of play the Spring assisted Idler pulley allows is there any other adjustment for the Belt?
When installing the belt it takes every spare inch of adjustment to get the belt over the last pulley. I mean it is tight! I actually thought maybe too tight. Did any of you 185mm owners have the same thought when you installed yours? Am I missing a place which allows a miniscule ampount of slack?
Thanks for any input.
Mike
