I just checked...3 Contitourings, but one of the rears is an INvo, summer-rated, but correct sized and Z-rated.
Thoughts?
Originally Posted by SRT6 Gang Member
I’m going to say yes because the leasing agreement specifically states all (4) tires must match and I believe should be Z rated. They don’t have to be OEM (PS or Cont’s) but they do have to be a matching set. I had factory PS fronts and Kumo’s on the rear prior to grounding, so I bought a used set of Cont’s (4) from forum member MUTT. Worked out because they were in need of replacing and MUTT saved me a lot of Benjamin’s. The dealer actually checked all four tires during the walk around and stated, “good matching set”.
See if you can find a used tire to match the other three…..
