Old Sep 25, 2008 | 05:34 PM
  #51 (permalink)
nox1s's Avatar
nox1s
Default Re: How-To: Install an Aftermarket Stereo
Originally Posted by drivethruecp
Thanks a lot, I actually did have the mute connected. But even with it disconnected. Still same problem! Does the Blue/whit from the factory connected to my remote alpine or the antenna alpine? I tried both with no luck but still wasn't sure which to use.
Like I said the headunit works just no sound. Not even a buzz. I even get the beeps from the button pushes which are from a speaker in the alpine. I put the stock back I'm to check and the stick still works perfectly.... I'm stumped..
Are you using a wiring harness or did you splice directly into the stock harness?
The blue/whtie from factory should connect to the remote alpine wire. Make sure that is connected.
