Old Sep 27, 2008 | 12:00 PM
  #57 (permalink)
drivethruecp's Avatar
drivethruecp
Default Re: How-To: Install an Aftermarket Stereo
Originally Posted by ppro
What's the brand and model number of the harness you got? Perhaps it's the wrong one? The one I used was a Schosche VW01B
Note that the chart above shows the colors and the illustration shows the back of the factory head unit. So the positions of the pins on the car plug are mirrored when compared to the appearance of the harness plug attached to the head unit, which should match the drawing.
This is what the car plug looks like:
You should not be getting the pop when it comes on.
I have the Scosche VW01B for a fact, the amp wouldn't power on apparently. But switching the pin over to the correct spot fixed it. The spot where the blue pin originally was is blank on the stock connector, so I moved it over to the spot to make the connection. My car is 2007 if that makes a difference. Very odd!!
