Originally Posted by getshawty
Iv had a thought.
If i change the headunit , Then could i change the amp for an aftermarket one.
If so which would anyone suggest and would it need to be 4 channel or 2 channel.
I dont want do fit a sub or any other upgrades .
Are all the speakers in the car run off the amp.
Sorry for all the questions
You were thinking it was the amp that was bad so you have two choices
1. replace it and soldier on
2. replace it and the head unit (a much more involved and expensive choice)
If you're confused, I'd stick with option one - a simple swap.
If you have no budget to consider, by all means, option two - and probably turn the work over to a competent stereo installer...
