Old Oct 2, 2008 | 05:32 AM
  #200 (permalink)
ChuckNorris's Avatar
ChuckNorris
Default Re: The official eaton supercharger thread.
I had coolingmist size the nozzle for 330 hp. I'll have to contact them to find out the flow. I'm sure you could work out a propane injection kit. What size tank are you going to use? I'm using a hobbs type adjustable pressure switch to activate the relay for my pump and I'm sure you could do the same for the propane minus the pump.
Originally Posted by BlueStorm
Mr. Norris,
I was curious if there is anyway I can run Propane instread of the methanol kit?
I'd rather go propane since I have all the parts, and there are no pumps require, it has great atomization and it's cheaper and much more readily available than methenol.
please advise if there is enough room or any possible way to get enough propane to flow into the manifold with just a NOS jet?
How many CC's will your meth kit be spraying?
