Old Oct 2, 2008 | 02:30 PM
amx1397
Default boost gauge installed
everyone likes to remove the Y below the SC and drill that ,well i didn't want to do all that work so i looked over the manifolds and was going to drill and tap on the drivers side which has more room but being i had the pass. side off the car i just measured and drilled ,tapped and installed the line ,, i have not found a good place in the car for it, but may build a pod in the glove box to hold my gauges or may build a pod that fits on the dash, what ever i decied i will post pic then as of now here are the pic of the manifold drilled tapped and gauge is working great 14lbs of boost stock and 16 with the code 3 pully. jim
