boost gauge installed
Old Oct 7, 2008 | 04:32 PM
Default Re: boost gauge installed
TVT looked everywhere so they would not have to drill and tap i would asume they tried those hoses, that is why i didn't bother also i wanted boost and vac. jim
Old Oct 7, 2008 | 04:38 PM
mrphotoman's Avatar
Originally Posted by Montana Crossfire
What are the little black hoses for?
I did not trace them but I would suspect it goes to the stock "boost" gauge that the computer uses to caculate from. If i get time i will look it up, who has access to the engine schematics?
Old Oct 7, 2008 | 07:39 PM
tighed1's Avatar
Originally Posted by amx1397
you could drill and tap right at the end of your arrow,, i did that on the right manifold,, as those little hoses do not connect to the manifold. jim
Those are on the intake side of the SC. No boost till you go through the SC.
Old Oct 7, 2008 | 07:50 PM
rcompart's Avatar
i have not found a good place in the car for it, but may build a pod in the glove box to hold my gauges or may build a pod that fits on the dash
Are you only going to run a boost gauge or do you plan on running multiple gauges in the future such as A/F, fuel press, EGT, ect? We offer pillar pods if that is something you're interested in. We also could custom fiberglass something for you if you wanted to take it in a different direction. Let us know if we can be of any help.
Old Oct 8, 2008 | 05:52 AM
i plan to run two gauges , boost and AF I think that is it.
Old Oct 8, 2008 | 01:43 PM
Mimi05SRT6's Avatar
You would think there is a vacuum line somewhere to tap into like other cars. I was able to tap into my turboed cars with no problem. Are all supercharged cars the same that you would have to tap into them the way peeps are tapping into their Crossfires???? Can't believe we have to drill somewhere just for a vacuum.
Old Oct 8, 2008 | 01:47 PM
mrphotoman's Avatar
no, on my old car which was roots supercharged it was as simple as T'ing into a vaccum line that came out of the intake manifold.
Old Oct 8, 2008 | 02:10 PM
MikeR's Avatar
I think that since the SRT6 is using a MAP sensor there is no need to run an extra line. Even if they had a gauge from the factory they would still just pull the data from the ECU most likely.
Aluminum is easy to drill and tap so it is pretty simple to add the fitting.
MikeR
55chevy
Jul 22, 2024 02:31 PM
UNDER PSI
Nov 1, 2015 09:39 PM
amx1397
Oct 2, 2015 05:20 PM
bbsrt6
Sep 19, 2015 11:21 AM
xfireon20z
Sep 10, 2015 04:27 PM
