Old Oct 2, 2008 | 06:39 PM
MD SRT6's Avatar
MD SRT6
Default Re: boost gauge installed
Originally Posted by amx1397
everyone likes to remove the Y below the SC and drill that ,well i didn't want to do all that work so i looked over the manifolds and was going to drill and tap on the drivers side which has more room but being i had the drivers side off the car i just measured and drilled ,tapped and installed the line ,, i have not found a good place in the car for it, but may build a pod in the glove box to hold my gauges or may build a pod that fits on the dash, what ever i decied i will post pic then as of now here are the pic of the manifold drilled tapped and gauge is working great 14lbs of boost stock and 16 with the code 3 pully. jim
A cleaner look is to put the fitting in the back of the drivers side mani, so it's not seen/ or in the way! No need to stretch it way over there?!
