Re: Still get overtemp no SC with Code 3 pulley and new johnson pump
I have been here, you more than likely have air in the I/C circuit. Look over my posts re the H/E issues and see how I got out the air by pinching the hose leading out of the I/C. You can see my Utube video part #2 that shows water flow.
The heat build up takes a bit of time and you can run till you hit the wall thermally. Be sure that the water has been cleared of air in the H/E and I/C system. It takes time and a bubble will vastly reduce the cooling available to your car.
The super charger only runs in gear and above about 1300 rpm, until you come to another stop; though several have not been convinced. I have done several tests to demonstrate this operation. If you have the red wire getting 12 volt power you should be ok.
If you pinch the hose coming out of the I/C can you feel the water trying to go thru it?
Let us know, Enjoy. WOODY
