Still get overtemp no SC with Code 3 pulley and new johnson pump
Old Oct 9, 2008 | 05:29 PM
  #41 (permalink)
MikeR's Avatar
Default Re: Still get overtemp no SC with Code 3 pulley and new johnson pump
Okay. I was thinking that the factory piece was on the bottom. As you can tell, I havent had mine out yet or the bumper off. I was thinking of the bottom deflector actually sitting below the bumper about an inch and pulling more air up from underneath. Curbs would be the biggest worry and since our cars are so short I am usually not anywhere close to them. I'll do some cogitating when I get to installing the LET HE from Woody.
MikeR
Old Oct 13, 2008 | 09:53 AM
  #42 (permalink)
tighed1's Avatar
Originally Posted by waldig
Next week a fabricator of super car goodies will be announcing the release of the "Super Cooler" as it has been called. They are doing the design of my approach and will be fabbing a kit approach to allow the easy installation. ITs all real easy to install the radiator and it does work well as a H/E. The relocation of the P/S cooler is the only work involved because I did the quick approach and re bent the stock tubing. Final design may be a separate cooler for better cooling and ease of DIY work.
I had thought of doing the assembly but I love playing with my cats, airplanes R/C, 440 6pack dodge, and generally playing at the young age of 61. My last company started in 1988 doing refrigerant recovery machines and I really dont wanna work, dabble yes, work no. I am doing development and design for the fun of it and dont even want money, just a few odd parts for my own car.
Next week should arrive sooner than christmas and it will be good.
Woody, P.S. this is not the October suprise for the track on the 12th.
Is it next week yet??
Old Oct 23, 2008 | 07:40 AM
  #43 (permalink)
tighed1's Avatar
Update. Calling it officially solved.
Moved the heat exchanger to a higher location in the air flow (Dr. Woody's suggestion) and so far I have NOT had the issue of going into overtemp with the supercharger shutting down!
All of you stock guys now running a aftermarket pulley keep this in mind of you encounter this problem.
Thanks to all that had suggestions/comments!
dj
Old Oct 23, 2008 | 10:05 AM
  #44 (permalink)
cruzinquick's Avatar
The true test will be when summer comes around again next year. The days are cooling off really nice now.
Old Oct 23, 2008 | 10:20 AM
  #45 (permalink)
BrianBrave's Avatar
<--- Huge Horsepower
Everyone thought (including me) that I would be the one chasing the dreaded IAT overtemp issue when I purchased the 185mm pulley
Never an issue for me....(knock-on-wood)...any improvement over stock never hurts and should give you some engine timing back...
Old Oct 23, 2008 | 10:21 AM
  #46 (permalink)
mrphotoman's Avatar
dj
that is very strange you had to do this, mine has ran flawlessly in 90+ degree weather even on 6+hour trips and racing.
Old Oct 23, 2008 | 11:22 AM
  #47 (permalink)
BLKFIN's Avatar
ADDICTED TO BOOST
I agree with you photoman. Mine has worked flawlessly in 108 degree TEXAS temps for the past 6 months.
Old Oct 23, 2008 | 11:27 AM
  #48 (permalink)
You are both correct, I think it's something in the water.
Old Oct 23, 2008 | 12:25 PM
  #49 (permalink)
tighed1's Avatar
By then I will have come up with a better HE cooling system.
Old Oct 23, 2008 | 12:36 PM
  #50 (permalink)
waldig's Avatar
For inspiration, look at the videos of the H/E and the track day at mir. I had a vid for the afternoon, but decided to hold off doing it, the air got up to mid 80 and was similar in readings , up fast down fast. Woody ENJOY
Old Oct 23, 2008 | 12:42 PM
  #51 (permalink)
ohnoesaz's Avatar
Tighed, I would definately do some investigating. Something is up. I put on a code3, and heck I even had it installed wrong, and its been 93 degrees this week in Tucson and my temp gauge never went over half and I've never lost S/C.
If you've already flushed your system, and you're sure your pump is working fine, then maybe look into the intake air temp sensor... Its readings are the sole deciding factor of if the computer shuts off the s/c clutch. If yours is quirky, or hey maybe even just covered in oil, it might give erratic readings with the hotter IAT from the code3.
Anyways glad to see you're having fun again. And good job on the H/E re-mounting. I didnt want to re-mount mine so I'm, well, uninstalling it completely and putting in a few fluid coolers instead, including one behind the upper grill.
Old Sep 13, 2009 | 12:44 PM
  #52 (permalink)
tighed1's Avatar
Time to bring up this issue again as there have been new developments.
To quickly sum up the problem, after installing the Code 3 pulley my car would overtemp shutting down the supercharger circuit.
Well nearly a year later I had to return the car to 100% stock for warranty work, supercharger replacement. While changing the SC they decided to replace the intercooler also. I have since re-installed the code 3 and the 181 pulleys and now have no overtemp issues even while running the stock heat exchanger in it's stock location.
So it appears that my intercooler may have been the problem all along as far as the over temp issue goes. Just wanted to update in case it can help someone later.
Now I have to put the tighed1/woody super cooler back on so I can be even cooler!
Old Sep 13, 2009 | 01:00 PM
  #53 (permalink)
nice to go back once in awhile and get updates...I have yet to have any real shut down problems with the C3. I haven't done any cooling mods to date, and haven't installed my johnson pump yet....so, I know in the future I need to do this, but the car is performing fine right now...thanks for the update...although I did have to replace the SC temp sensor...which could give same indicators...
Old Sep 13, 2009 | 07:41 PM
  #54 (permalink)
waldig's Avatar
Talking Re: Still get overtemp no SC with Code 3 pulley and new johnson pump
Early on I posted the problem I had with my cooling system and that I ran radiator cooler cleaner thru it and drained it into a cloth. THe cloth had lots of gunk in it and I believed that there was a film build-up on the walls of the radiator and heat exchanger surfaces. I suggested then that if another member had heating issues, they should flush with cleaner and drain it to see if they also get gunk in the cloth.
Its a thought and cleaning the system should be done every couple of years anyway for preventive measures.
Woody
Old Sep 13, 2009 | 07:48 PM
  #55 (permalink)
32krazy!'s Avatar
Woody
woody considering how particular m/b is with the cooling system , meaning only run their coolant with distilled water. what did you use to flush the i/c? this seems like something that should be done when the rad is flushed as a preventative measure. when i flushed mine i only drained all the fluid ran pure distilled water then drained again and filled with 50/50 mix. i would gladly drain it again and flush it to clean the i/c if i knew it wouldnt hurt my engine over time
Old Sep 13, 2009 | 07:59 PM
  #56 (permalink)
waldig's Avatar
Me Iam a Prestone guy and use their flush and their antifreeze with 50-50 distilled water. NEVER failed me and I even run with the presure cap loose so there is not pressure on the system. I dont like the accordian pressure effect of going 0- 17psig every time I start the car and then 17
-0 when it cools.
Me Iam old and have replaced my share of heater cores and soldered too many radiators after I rodded them -- you dont wanna know what that is.
Remember clean is next to impossible and
Clean is invisible
Woody
Old Sep 14, 2009 | 12:36 AM
  #57 (permalink)
ZAHANMA's Avatar
Sometimes its fun to see old threads get updated...
I actually had this same problem, my turned out to be a bad ambient air temp sensor. It kept telling the computer it was -40F outside, causing the computer to dump fuel t compensate for the really cold air. This would cause S/C overtemp and shut it off...
Pulled the sensor and all good, now its been replaced.
xfireohio
Jul 20, 2020 12:03 AM
Dementors
Oct 9, 2015 07:22 PM
Tp'sfury
Aug 13, 2015 08:20 PM
Tp'sfury
Jul 17, 2015 01:15 PM
