Old Oct 23, 2008 | 10:21 AM
  #46 (permalink)
mrphotoman's Avatar
mrphotoman
Default Re: Still get overtemp no SC with Code 3 pulley and new johnson pump
Originally Posted by tighed1
Update. Calling it officially solved.
Moved the heat exchanger to a higher location in the air flow (Dr. Woody's suggestion) and so far I have NOT had the issue of going into overtemp with the supercharger shutting down!
All of you stock guys now running a aftermarket pulley keep this in mind of you encounter this problem.
Thanks to all that had suggestions/comments!
dj
that is very strange you had to do this, mine has ran flawlessly in 90+ degree weather even on 6+hour trips and racing.
