Re: Still get overtemp no SC with Code 3 pulley and new johnson pump
Early on I posted the problem I had with my cooling system and that I ran radiator cooler cleaner thru it and drained it into a cloth. THe cloth had lots of gunk in it and I believed that there was a film build-up on the walls of the radiator and heat exchanger surfaces. I suggested then that if another member had heating issues, they should flush with cleaner and drain it to see if they also get gunk in the cloth.
Its a thought and cleaning the system should be done every couple of years anyway for preventive measures.
Woody
