Originally Posted by waldig
Early on I posted the problem I had with my cooling system and that I ran radiator cooler cleaner thru it and drained it into a cloth. THe cloth had lots of gunk in it and I believed that there was a film build-up on the walls of the radiator and heat exchanger surfaces. I suggested then that if another member had heating issues, they should flush with cleaner and drain it to see if they also get gunk in the cloth.
Its a thought and cleaning the system should be done every couple of years anyway for preventive measures.
Woody
woody considering how particular m/b is with the cooling system , meaning only run their coolant with distilled water. what did you use to flush the i/c? this seems like something that should be done when the rad is flushed as a preventative measure. when i flushed mine i only drained all the fluid ran pure distilled water then drained again and filled with 50/50 mix. i would gladly drain it again and flush it to clean the i/c if i knew it wouldnt hurt my engine over time
