Re: Still get overtemp no SC with Code 3 pulley and new johnson pump
I don't own a code 3 so I haven't installed one, but from reading your problems is sounds like a thermal expansion problem. Either you're not leaving enough space when the shims are installed ( which it sounds like you are) or you are having a spacer that starts to warp under heat which is causing drag on the supercharger and causing it to be engaged all the time. This would cause the intermittent problem
