Originally Posted by tighed1
May get adventurous this weekend and drain the coolant system as Woody stated. A visual look at the coolant along with the small amount that drained when I replaced my IC pump indicates that the coolant is VERY clean. Doing this will give me another opportunity to become more familiar with the car.
I'm going to pull the Code3 pulley for now. Hate not knowing when I'll have boost or not. Plus it will give me a chance to see what my stock boost is now that I have installed the boost gauge.
I agree with Woody's statements on the operation of the supercharger. Hey Woody, how about just replacing the stock IC with the one I mentioned? I may have a aluminum radiator laying around maybe I'll look for it, modify it and install that instead. Whatever...!
Woody explained in his long H/E posts that the main negative in our S/C cooling system is the lack of air reaching the heat exchanger. Basically, you're better off mounting your stock H/E in front of the upper radiator rather than using a better H/E (Like the LET one) in the stock position.
you're best off with a better H/E in front of the upper radiator. So yes, if you have something that gives better flow and will fit in front of the upper radiator then that would work great.
