Old Oct 9, 2008 | 03:59 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Still need oil pressure gauge solution.....
Making a kit has proved nearly impossible as it doesn't solve the original issue of tapping into the Oil Filter holder.
You will need:
2, 1/8" NPT Male into 1/8" NPT Female
3" long tube with 1/8" NPT Male
That's it then just screw in the sending unit.
You will also need a 46mm or 1 7/8" ratchet to remove the oil filter housing.
