Originally Posted by TVT_DESIGN
Well the SRT one is like 3X5, which is nothing. A typical oil cooler is about 10x in square inches.
Bluestorm, are you running your oil through a cooler?
Yes, I scored a large Earl's Plumbing oil cooler, it even has brushless fans for cooling the oil durring idle conditions. I just haven't had time to mount the temp sensor yet.
I need to do a long drive and monitor the timing again, as I my theory was this mod will reduce the oil temp from the piston sprayers and thus putting less heat into the pistons, causeing the timing to be reduced. we'll see what I find out this week end. I'm hopeing to see a big drop in the Temp with fans a blowin"
