Oil Cooler for the N/A
Old Oct 28, 2008 | 05:33 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Oil Cooler for the N/A
Originally Posted by AllEuro
How is 20 weight oil thicker than 40 weight?
I'd like to see some pics of the cooler installed on the car if possible. Good job getting it all together!
5W id thicker then 0W, MB has actually switched over to using 5W30 on all of their vehicles.
The pic above is of it installed on the car.
Temps have dropped about 45 degrees. It is in the 190 range. This is with normal driving. Once we track it we will have a better idea of the effect.
Old Oct 28, 2008 | 06:37 PM
AllEuro's Avatar
The problem is that the first number is the cold viscosity of the oil and the latter is the warm viscosity. The warm viscosity is the most important, so if you are worried that 40 weight is too thin, you should move to a 50 weight oil with a small cold weight, like 0w50. Once the engine reaches operating temp, the 5W is no different than the 0W. I guess I'm confused at why you move to such a thin oil. I;m guessing becuase the car stays much cooler than stock? Have you noticed an increase in engine responsiveness with such a lightweight oil.
190 is pretty darn cool! I was driving BMW's all weekend and spent some time with the 3.0tt motor and those cars were hovering just below 250 degrees during normal and enthusiastic driving. Damn those motors are wonderful! Too bad the price tag associated with cars with that motor is a bit prohibitive!
Old Oct 29, 2008 | 02:57 AM
TVT_DESIGN
Guest
Posts: n/a
I wanted a thicker oil when cold, because the Ow just didn't feel safe. You could hear the valves ticking away until it warmed up.
A thinner oil at operating temps allows for less drag and thus more HP. I don't know if it feels more responsive, but with the DBW more responsive is hard to measure.
Old Oct 24, 2009 | 07:34 PM
TVT_DESIGN
Guest
Posts: n/a
It has come time for me to sell this unit. It is in an area that will be taken up by another "cooler".
I will include all hook ups and lines needed to have a direct bolt in on the Crossfire.
Price will be 350 plus shipping.
TerryR
Dec 13, 2019 03:27 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
