Old Oct 19, 2008 | 04:24 PM
ImportLabSRT's Avatar
ImportLabSRT
Default Re: Code3 Performance to visit LET!!
Originally Posted by cruzinquick
Actually if you burn out long enough the second wheel locks up and begins to burn out too. Once this happens, and usually takes a few seconds after the first one starts. They stay locked for the launch. It's actually pretty good, almost like posi at launch.
On the converter, I believe it's the supercharger kicking in that hard to hold back. A tip is once you light the first bulb, then get on the brake hard and rev it up to load the converter as much as possible and it pushes you into the second beam, then hold the brake as hard as you can and be ready to let it go on the 3 yellow as they light up. You should get a great launch and 60' time which will lower your overall time. Mph is always lower on your fastest run. If not, then you are leaving a few hundredths on the launch. Be safe and have fun. Lot's of practice to have great 1/4 mile times.
Thanks for the tips. It was a few first for me.... First time at the track in the Crossfire, First time with an automatic and first time with a RWD. I have high hopes for this car and it was a blast at the track and very consistant. I have 12-15 time slips all with in 2 tenths of a second.
