You can do it yourself. Order the bosch ford lightning pump, as it will be easier to install. You actually don't even need to disconnect the hoses, because you are using the same top. Just remove the screws from the top and the body of the pump will remain in the bracket. Remove it and reverse the procedure, then get the plug to wire into factory wiring. You should use hose clamps to pinch the hoses, to help keep the water in the lines and not on your garage floor. here's one but plenty others on ebay. Remember to get the plug or just use spades to plug into the bottom of the pump.
http://cgi.ebay.com/ebaymotors/03-F-...mZ170272871905
Originally Posted by rodimus
I'm just going to order the Johnson Pump.
I've read posts saying that it is a easy install. Would you guys recommend installing this by someone with limited auto skills? If not, can any reputable mechanic do this or is a MB mechanic a better choice??
On a positive side note.... I was venting some frustration last night and told my GF I have to order a "Johnson pump", and she said "You don't need one of those things baby". haha
I said, unforutantely my car does though. She said I thought cars were usually woman??
needless to say was a very funny conversation that was needed, because Chrysler has been pssing me off quite a bit.
