Sometimes Sluggish acceleration
Old Oct 24, 2008 | 08:59 AM
  #241 (permalink)
MikeR's Avatar
Default Re: Sometimes Sluggish acceleration
LOL...Rodimus you are correct on the install. I was on a different train.....
MikeR
Old Sep 12, 2010 | 08:44 PM
  #242 (permalink)
WingMan's Avatar
Re-opening this ancient thread, since it seems to be the "account of record" on the problem.
Chalk me up as another victim of the failed pump. It failed about 13,500 - 14,000 miles.
This thread was instrumental in getting the problem fixed. My dealership admitted that, well, there was some note somewhere in the company records about this pump problem. "But..."
So I printed out the first 20 or so pages of this thread and left it with the car at the dealer. It was no longer "my car;" it was a changeling that had the acceleration of my 1974 New Yorker.
After about 4 or 5 days, I got my car back. I mean, I GOT *MY* CAR BACK! The one that I bought in the first place, the one with that provides the jaw-dropping power when needed. Fortunately, I still had time left on my power-train limited warranty, so the repair was covered.
Since this thread was so helpful, I thought I'd pay it forward. Here's the write-up from the dealer. Might be helpful if this problem happens to you.
Customer states vehicle has no boost from supercharger when it is warm. Check and advise. Road test and verify complaint. Check for codes. P011 = intake air temp sensor circuit high. Check intake air sensor. Voltages and values are within spec. Connector and harness at temp sensor: OK. Found case K80420155. Check air cooler circulation pump. Check power and ground. Found fuse13 open. Replace air circulation pump fuse 13. Confirm operation road test. Condition duplicated after road test. Found fuse blown. Insect wiring: OK. Pump causing open fuse. Replace air circulation pump. Replace fuse. Clear code. Road test. Confirm repair.
Danyuhl
Nov 2, 2019 05:18 PM
bbsrt6
Feb 16, 2019 12:39 PM
velociabstract
15
Sep 7, 2015 03:43 PM
Aug 11, 2015 05:19 PM
Just1n
Aug 8, 2015 11:45 PM
