Old Oct 21, 2008 | 01:48 PM
entropy's Avatar
entropy
Default Re: Auto Trans wont shift - dealer and tech can't find cause
wow..that sounds expensive..do you have the powertrain warranty...ok...it was the sensors, then pump, then now abs control module....do u have an auto stick or standart, it makes a huge difference because ur car shouldnt be stuck in 2nd gear if its standart....but the abs has nothing to do with the automatic transmission....lets think about the fluid..did u change it, is ur check engine light on, which exact codes come up on the scanner..i can help you by tracking the code to come up with possicble issues...send us a list of codes that came up..what exaclty did the tech say...did he give u peice of paperabout the repair...how much does he want to charge..maybe anthony from tvt for hddp can tag in on this..after we're all owners of the same car....
