Old Oct 29, 2008 | 09:42 PM
cruzinquick's Avatar
cruzinquick
Default Re: I'm going faster.....but not enough yet
Those are great times MikeR. You were only a few hundredths off the fastest pass ever just 12 months ago. Wow your DA is calculated at 81ft!!!! That is killer. I would love to make a pass in your car. I really hope you can make it. You will see your times come down once you get comfortable with your launch. The burn out doesn't have to be that long, but you do have to spin the wheel long enough for the drivers wheel to spin also. Usually takes about 4 seconds to get the other one spinning. Once both spin keep it there with the brakes lightly for another 4 seconds and your good. I try to roll very little after and do a dry hop. Meaning hold the brake and give it some gas and let go, if the tires spin they are still a little wet. Do it again. Just be careful not to pass the staging beam.
