Originally Posted by Tazz
I "tied" the two rubber mounts together with a big cable tie/zip tie to keep them from slipping off -- I had to use some lube to get the tight one on the MF (that stands for MagnaFlow now, but not at the time of installation.......)
I seem to remember a few explitives coming out of my mouth during the install. I think that rear rubber exhaust hanger is the most over engineered part on the car . . . but it did have AMG printed on it. I need to learn to swear in German, perhaps that will help with future installs.
Anyway, I did the same zip tie trick.
I had one side that kept coming off, this resulted in the exhaust banging off the rear lower control arm on the drivers side when I made hard right hand turns. By pulling the two rings in tight together with a zip tie it eliminated the the exhaust hook from sliding off the hanger.
