Important Question Magnaflow
Banned
Originally Posted by Tazz
I "tied" the two rubber mounts together with a big cable tie/zip tie to keep them from slipping off -- I had to use some lube to get the tight one on the MF (that stands for MagnaFlow now, but not at the time of installation.......)
Originally Posted by lowwkeyy
did u have to cut the old pipe off
did u have to weld the new pipe on ?
If you have a Roadster it's a little more complicated because you have to remove the underbody brace.
jimf
Oct 10, 2015 10:22 AM
