So what do you guys plan on doing next to your 6?
Here is mine, in order of importance.......
1. Tires!!! I'm in desperate need of new meats. Probably going to go with the V's
2. Exhaust (It's been sitting in the garage too long!! Waiting on a friend to do it)
3. Brandon's PCV solution......When I removed my NW Intake mani's there was a ton of oil around the Y pipe and actually some on the gaskets themselves. I know this can't be a good thing.
4+5 will kinda go together......
4. SC pulley along with a LET re-tune. I also might need larger injectors at this point......In my opinion, the 178 + the SC pulley will compliment these NW Intake mani's quite nicely. I saw about 2.5 to 3 psi decrease from adding the NW mani's so by adding the SC pulley, we would not be maxing out the map sensor as Eleventeen did.
5. AIS stage 2 water/meth system along with another LET re-tune. With the added heat, ya gotta do something to keep those IAT's down! Also by running the meth system, you wouldn't be loosing much in the heat of the summer!
6. Pray my shyt doesn't go KABOOM!
