Originally Posted by The Beep
First, the clips wouldn't attach securely to the new injectors and needed to be modified.
Fourthly, the new tune removes the rev-limiter. For 6 spd users, you are free to blow the motor if your not careful with the 1st gear. I haven't tried it yet but it appears, with the increased power, I could use WOT in 1st gear for less than 1 second.
The clips and wiring harness snap right into place once Anthony posted how to install the injectors.....they do not go into the fuel rail as far....back them out about 1/8 inch and you will see a slot for the clip. I had to re-install to get them in correctly.
I hope you are right on #4. I haven't tried it yet since the tune but hit it a few times before just as I was getting ready to grab another gear.
