Old Nov 11, 2008 | 09:22 AM
corfire's Avatar
corfire
Default Re: Delay wing deployment to 75 mph
Originally Posted by +fireamx
Maxwell, just tap into the fuse box on the drivers side and "hot wire" the wing fuse with a "on-off" switch and you can shut the wing down until you hit the switch, at what ever speed you want it to go up.
Just be sure to put an in-line fuse to take the place of the original fuse that you pulled.
This part of the quote is very important. If you remove the original fuse and don't install one in line with the switch, a shorted circuit could cause damage in the form of burnt wires or even a fire. Fuses are there for a reason.
