Old Nov 12, 2008 | 04:27 PM
RAM82A1's Avatar
RAM82A1
Default Re: Battery problems-again!
Originally Posted by buff5
Thanks Chris, I understand BUT how do you explain the battery going dead after 2 days EVEN with the Negative cable disconnected???. Got to be the battery, I charge it to full, leave it sit two days with cable off, thus 0 drain & it still goes dead.
No doubt the battery is bad. Question is did it die a normal death or was it hastened by excessive drain? In any event, once you get your new battery, you can try the current draw check again.
