Old Nov 13, 2008 | 04:32 PM
tighed1's Avatar
tighed1
Default Re: Crud. Broke supercharger clutch bolt.
Dude!
That suks!
NeverEnough broke his also. He said that the bolt was hollow inside and was easy to take out with a bolt extractor. Once you find out the size, POST it so we have a record of it.
Dude, that suks!
His story...
Originally Posted by NeverEnough
Personally, I think strap wrenches are total GARBAGE! I bought the Red/Blue set pictured above just for this purpose. I broke the Blue on in the process and cut a grove in the Red one. After all that, I borrowed a heavy duty steel one about 2 feet long from a plumber friend of mine. Still could get the bolt off. It finally came off with a breaker bar. The problem then was the GD bolt BROKE OFF!!!! Luckily it was hollow, so a bolt extractor was able to get the rest of it out. I replaced it with a Grade 8 Allen head bolt and forged steel washer. I used an electric impact with a 30 ft. lbs torque stick to put it back on. To ANYONE doing this, I recommend using an impact gun(carefully) to loosen the bolt before taking the belt off, and again to tighten it once you put the belt back on. Just my $0.02.
