Old Nov 30, 2008 | 11:25 AM
Valk
Default Re: Cabin Filter and Base Coupes
Originally Posted by 70GT6
While under there - you can see the fan motor. There are white/yellow clips that hold the motor& fan in the car. About 6 inches toward the center of the car there should be a 2" x 8" (about) rectangle piece of plastic held by clips similar to those on the fan motor. Sliding the clips releases the cover and reveals the filter. Pull down to remove filter (if there)
Posted by Andrew....
once you remove the lower cover/panel under the glove box & passenger foot well area.
this is what you see...
you need to slide back each clip (off white color) to remove filter cover... then pull filter out (it stands up on end).
pic of cover removed:
pics of filter at 25k (new - old): revised m/b part number
