Old Dec 2, 2008 | 07:07 AM
Voyager's Avatar
Voyager
Default Re: driver side interior door handle
Originally Posted by taurusjds
We had the same problem on my wife's Crossfire. Out of warranty though as we bought it used.
Sharp enough to draw blood and it did.
I got in behind it with one of those foam sanding blocks from the hardware store (fine grit) and then finished it off with 600 grit sand paper. Up and down movement with the block to knock off the sharp edges and side to side with the fine grit paper to finish it off smooth as it should have been all along.
Problem solved according to the wife !!
did the same thing it works great
