don't go with oem replacement as it will not be a good choice for you, go with optima red top or stinger. go on ebay and use cashback through live.com which currently is 15% and i have seen it seldom at 25%-30%. for cap a larger one will not hurt you it can be an overkill but if you ever plan on adding an amp to the door speakers or run dual amps get a bigger cap than smaller. i use the 5 farad power akoustic. you should install the hid's first since it uses much less power and will greatly reduce the dimming of the headlights. you might still see interior lights dim but with the big three upgrade, cap and optima redtop it will cure most if not all of your issues.
Originally Posted by 07bluezx14
Any suggestions, on battery brand. I am leading towards something like oem replacement. Do all of the batteries that fit our cars, have a vent? I have never had one with a vent. And as far as capacitors go, what size would be overkill, for 600wrms. Will a 3 or 5 farad store more power, or do I really only need a 1 farad. I was looking at power acoustix caps on ebay and a 5 farad is 70 bucks. I just figured 1,3,or 5 F would work. Will a larger cap cause any problems? thanks, chris
What else will I need to install the capacitor?
And I have the hid's sitting in front of me, low beam, and fogs. I just wanted to address the power issue before installing them.
