Old Dec 7, 2008 | 04:56 PM
ppro's Avatar
ppro
Default Re: What do I really need???
Originally Posted by 07bluezx14
Well I put in the hid's fogs, and low beams. Awesome lighting upgrade. Didn't help the dimming problem, now it is more of a strobe look. But it is out of the way. now I can't decide to do the big three, before or after I get the battery. So as a primary battery, get a red top? I really don't want to run two batteries. How they wired my power wire doesn't seem right, it is shared by whatever else comes out of that block, which is fed by a smaller wire than the ground wire. What do you guys mean by breakers? Well thanks for putting up with all of my confusion, and keeping me pointed in the right direction. Thanks again, chris
I'm sure this isn't over though
If you can get a Red Top Optima that fits, yes, as opposed to the Yellow Top. I want to put a Red Top in mine. When I do, I will be carefully comparing the battery case size and terminal sizes so that I can get one that still fits in the tray and clamps down tight, and the terminals fit properly (positive and negative on the proper sides, terminal post sizes fit terminals).
