Old Dec 9, 2008 | 05:49 PM
faiz23's Avatar
faiz23
Default Re: What do I really need???
this is pretty much what you want since you can use 2 or 4 agu for your main one for the car, and then you have 2 additional outputs
http://cgi.ebay.com/BATTERY-TERMINAL...QQcmdZViewItem
http://cgi.ebay.com/Stinger-4-8-Gaug...QQcmdZViewItem
i like the one with ring terminals so you have additional output if you want to run a wire direct to your HID. either one is good make sure you have enough output to work in the future.
I think the battery should work but make sure you have clearance to close your hood once you use the replacement terminals.
