Old Dec 14, 2008 | 01:06 PM
mattsmed's Avatar
mattsmed
Default Re: Key Fob Failure HELP. Urgent. Stuck 100 miles from home
Okay. I've tried the disconnect the battery thing. No joy. Even if you reconnect with doors closed, the alarm reactivates on reconnection. If you disconnect with door open, alarm re-sounds.
The anti tow alarm button is irrelevant in this case because I cannot switch off the normal antitheft alarm. i.e. when I manually open the doors with key, the alarm sounds. Engine starts then dies. There must be a manual override to actually disable the alarm? most of my cars have had a keyturn on the alarm box to disable. But I don't know where the alarm is to even try and see if it has an override.
